Question about N2O
Old Mar 15, 2007 | 11:36 PM
elliottpeach's Avatar
Question about N2O
Hi all, a quick opinion or two abouit N2O:
I just bought a "universal" NX Incognito 50 wet shot kit, to use with my TPI 305. does the N2O injector need to be in the intake, BEFORE the MAF Sensor, or between the MAF and TB? With a wet shot, I would assume between the two, shooting straight into the TB? But I just wanted some input...
Also, where can I get my N2O bottles filled? Do auto parts stores like Advance/Checker carry it, or where can I expect to look?
Thanks everyone!
Elliott
Old Mar 16, 2007 | 12:46 AM
TON*LOC's Avatar
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
put it as close to the tb as possible, i would try to put it on the botom of the tubbing and perfectly in the center so it goes threw each butterfly evenly
Old Mar 16, 2007 | 06:34 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Thanks everyone!
Elliott
if its a wet shot, it will go AFTER the MAF deffinately, but im assuming you have the nossle, so you would run that before the TB. The only places you can get nitrous filled is a race shop, chain parts stors (autozone, napa etc,) dont fill.
Old Mar 16, 2007 | 10:11 PM
TON*LOC's Avatar
i know checkers does depending on where you live
Old Mar 16, 2007 | 11:08 PM
I was wondering, thinking that Checker ProShop might stock N2O... I found some local speed shops close by, as well. One more question: Can I put a 100 nozzle on a kit like this, even though it only COMES with a 50?
Thanks everyone, I really appriciate it!
Elliott
Old Mar 17, 2007 | 07:41 PM
_Twisted_'s Avatar
Car: 86 Vette, 90 ZR1
Engine: 383 Minirammed, LT5
Transmission: 700r4, ZF6
Axle/Gears: 3.45/3.45
YOU SHOULD BE ABLE TO CHANGE THE JETS, CHANCES ARE THE JETS THEY SUPPLIED YOU ARE PIG RICH - MY SUGGESTION IS TO NOT WORRY ABOUT THE 100 SHOT AT THIS TIME AND GET IT RUNNING RIGHT WITH THE 50 FIRST.
MAKE SURE YOU HAVE AMPLE FUEL PRESSURE AND DELIVERY BEFORE TRYING THE 100 SHOT.
gOOD LUCK -
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
