N20 Purge question...
Old Mar 22, 2007 | 03:52 AM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
I have a 91 Z and am in the process of installing a NOS Cheater kit. The only problem I have is with the purge. I bought some brake line to use for my purge since I want a (V) purge. I have a 4" Harwood cowl hood (Bolt On) on the car and if I were to close the hood all the way, the inside of the hood will bend the purge lines against the cowl.
Can anyone show me pics of how they ran there (V) purge with a similar hood? Or give me some advice on what I can do besides drill into the hood to get the lines to clear?
Thanks.
Old Mar 22, 2007 | 07:17 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Re: N20 Purge question...
Run a flexible (pvc?) line from the solenoid to the hood, leaving enough slack in the line for full rotation of the hood. Then connect that to the brake line that you run on the hood. This way you are not bending a metal line everytime you open the hood. I am using this method as it was described to me through DynoTune when I ordered there 2 way purge setup.
Old Mar 22, 2007 | 08:12 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Old Mar 22, 2007 | 01:41 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
PVC?? Would vacuum line hold up to the Nitrous? When the hood is closed the flexible line will get pinched. Got a pic? Also, could you direct me to the link to dyno tune?
Old Mar 22, 2007 | 03:31 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
This is the kit that I bought to connect my purge solenoid. I don't actually have it ALL hookeup yet since the motor isn't in the car at this time.
http://www.dynotunenitrous.com/store...p?idproduct=68
Old Mar 22, 2007 | 07:21 PM
pairtoe's Avatar
wow thats awesome, esspcially for the price. im gonna buy one tonight.
Old Mar 23, 2007 | 12:21 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I have the 4" Harwood Outlaw hood and a nitrous system. I used copper tubing and compression fittings to run the purge lines through the firewall to the space where the wipers are then up through that mesh grill.
Tony
Old Mar 24, 2007 | 05:47 AM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Thanks for the link, I am going to go this route.
Old Mar 24, 2007 | 10:27 AM
Stephen's Avatar
Car: 87 GTA
When/if I get NOS, I'm mounting the purge aimed at the radiator, not out in the open. "NOS? What NOS? I'm NA!"
Old Mar 24, 2007 | 07:58 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Lots of options. I am also running that dynotune nitrous dual purge kit - works great.
Stealth eh? I hear ya but I just couldn't resist dual plumes out the 'nostrils' of my T/A hood
Good luck with your plumbing project.
-Schultzy
Galaxie500XL
Oct 1, 2015 01:05 PM
BWilcox
Sep 20, 2015 12:19 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
