Nitrous fuel pressure question
Old Apr 4, 2007 | 06:51 AM
camaro2.8173's Avatar
hi, i am planning on running a 100 wet shot of nitrous and just wanted to know what is the best setting for fuel pressure.(its fuel injected)
and for safety resons i am going to install a fuel pressure gauge in between the shrader valve and the fuel soloniod, so i can keep an eye on it. but waht should it run at, and whats to high and whats to low.
thanks
also i was going to get a fuel pressure safety switch, but i am unsure which one i would need.
Old Apr 4, 2007 | 09:06 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Nitrous fuel pressure question
check the manufacturerer's specs, but normallys its 45-48 psi for fuel injected motors and 4.5-6 psi for carb apps
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
