Procharger FMU question
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Anybody else have vacuum coming thru your FMU? Where the screw is to adjust at idle mine is pulling vacuum??? Not sure if it has always done this or what?
Ryan
Ryan
Re: Procharger FMU question
It should be pulling vacuum at idle. Under boost, it bleeds off any excess pressure. That's how you adjust your rate of gain without changing discs like on a Vortech FMU.
Understand part of that... It is actually leaking vacuum from the FMU--the hole in the adjuster screw has vacuum being pulled through at idle??
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
hows that new miniram running?
ehh.. running ok... I am still working out some bugs.. it seems to idle high and is a little hesitant off idle.. I am checking for vacuum leaks, already changed out the plugs and double checked the timing... It has more I just need to find it, I think a dyno tune is the only thing to do... Will keep all posted!
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
