what stall converter
Car: 92 Camaro Z28
Please give suggestions on what stall converter I should run.....
Setup: 350 (.040 over), 8.6 to 1, Forged internals, 230/236 .576/.570 113lsa cam, 1.6 roller rockers, Dart Iron Eagle Platinum Heads w/200cc ruuners, HSR intake, Holley 950 commander, T70 turbo (14 psi), 3 1/2" downpipe, 55lb injectors, TH350.......
I want the car to launch hard! But still be able to drive it to the local car show and the local street races.... I was thinking a 3000 stall
Ray
Ray
Car: 83 camaro
Engine: 383 stroker
Transmission: TCI 3spd manual
Re: what stall converter
Depends were your power curve is for your motor. Your motor appears to be built well. I always find myself going back to 3,000 stall converters for the street. anything higher is a bit too much and a 2500 is a bit to low. I would bet youd be happy with a 3000 for daily street use
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Like stated above, you want to find out the torque curve of the motor, and then the stall should be where the motor makes peak tq, so that way you're leaving the line right where the motor will pull the hardest. With that sized cam im going to say its in the 3500-3800 range, on desktop dyno my 241/249 dur cam makes it right at 4k RPM's
Car: 92 Camaro Z28
Jegs, has a 3200 stall converter w/balloon plates and is rated to 800hp... $399 Anyone running one of these?
Ray
Ray
Car: 83 camaro
Engine: 383 stroker
im running a TCI 3200 stall with an anti ballooning plate. The plate is designed to be used with nitrous applications to handle the excess stress on the converter. I paid 410 bux for it.
Car: 92 Camaro Z28
Ray
Hotrodboba400
Dec 10, 2019 07:07 PM
MikkoV
Sep 9, 2015 04:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
