turbo size question
Old Apr 12, 2007 | 11:07 PM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
turbo size question
wondering if i could get away with a .63 a/r turbo on a 5.0 sbc according to turbonetics for around 400 horse a .68 a/r should do but i can't seem to find one in my price range
Old Apr 13, 2007 | 04:40 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: turbo size question
What is the size of the turbo though .... like a 48 ... 62 ...76 mm ? I am not sure if it matters ( think it does) , but I think it would help others help you .
Old Apr 13, 2007 | 11:32 AM
blue82_z28's Avatar
Axle/Gears: 3.23's
well there's two that they suggest, a t04e-60 and a t04b both with .68 a/r
Old Apr 13, 2007 | 12:31 PM
wilbur1877's Avatar
what is your price range this is the one I just purchased approx 1700.00 new
*High Performance C117 Compressor and UHP Turbine*Brings GT Ball Bearing performance to the 700Hp class*V-band turbine outlet flange*T4 Turbine Inlet Flange
Horsepower 400 - 700
Displacement 2.0L - 6.0L
Ball bearing
GT4088RCOMPRESSORTURBINE
Turbo
CHRA
751470-1 751450-9751470-2 751450-9751470-3 751450-9751470-4 751450-9
Wh Dia
TrimA/R
Ind
Exd
63.5mm88.0mm520.72 63.5mm88.0mm520.72 63.5mm88.0mm520.72 63.5mm88.0mm520.72
Wh Dia
Trim
A/R
Type
77.0mm 78 0.85 Free Float 77mm 78 0.95 Free Float 77mm 78 1.06 Free Float 77.0mm 78 1.19 Free Float
TURBINE HOUSING OPTIONPart Number448375-18448375-19448375-20448375-21 Wh DiaTrimA/RType --0.85Free Float --0.95Free Float --1.06Free Float --1.19Free Float Oil & Watercooled Bearing
Old Apr 13, 2007 | 11:22 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
yea 1700 dollars is definitely out of the question, i was think hopefully under 300 bucks, but i mean i'm not looking to make 400 horses out of the engine i'm thinking maybe a little over 300, so would a turbo that is .63 a/r be big enough to support that much??
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
