Blown 383 E85 Q's
Old Apr 22, 2007 | 04:19 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Blown 383 E85 Q's
The motor is currently being built, and I just noticed that theres an E85 pump downtown.
383 pro topline heads
9:1 cr
vortech supercharger
It's a blow through system, and I was going to use a mighty demon built for it. Does anyone offer a blow through carb set up for E85?
Also is this something worth doing, I know I could run more timing and ditch the snow performance injection system. I understand that you can make more power with total timing and less boost. Is this true? Would I possibly be able to run total timing and say 12 lbs????
I just bought an A1000 fuel pump and it says its not compatible with alcohol.
Do I stay or do I go???!!???
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
