holley stealth ram on 305 ati procharged 13lbs
Old May 25, 2007 | 11:59 AM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
I have an 88 iroc with a stock 305 long block with edelbrock base, runners, ported plentium ati procharger p600b aftercooled 13lbs of boost car made 390 hp and 420tq to the wheels will I notice a gain from the stealth ram or should I just wait till I build another motor for the car?
Old May 25, 2007 | 03:21 PM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Re: holley stealth ram on 305 ati procharged 13lbs
I think you will see a huge gain but the only problem i see is how long will the stock bottom end hold up with even "MORE POWER".I''m guessingg that your are only revving that thing to around 4800-5000 right?With the extra rpm and more power you might reach the limits of that motor.
Old May 25, 2007 | 04:58 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I agree, my engine would be scattered if i revved it above 5500rpm. Thats why i still run a TPI intake. (it makes plenty of power anyways)
Old May 26, 2007 | 07:32 AM
Transmission: t56
My shift light is set at 5500 I usually shift at 5000 though thanks for the info guys
Old May 26, 2007 | 01:29 PM
ws6gta89's Avatar
Engine: 355 L98
Axle/Gears: BW 3.27
If you were to use the new intake even with the stock cam you would pull to 5500-6000 with no problem and the extra rpm is what would hurt you with the stock bottom end ,now when you build the new motor that thing will be sick with your setup...keep us posted
Old May 26, 2007 | 03:11 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
don't forget that the hsr requires "extra efforts" to seal the plenum to the base on boosted applications. i remember seeing one welded together on here, don't know how you'd get the dizzy in and out on an f-body though.
Old May 26, 2007 | 05:41 PM
Transmission: t56
check out my b4 and after pics of everything I did to the car under 88 procharged t5 iroc hard top in the classifieds.
9192camaro
16
Feb 3, 2019 12:21 AM
Mutillator
Sep 17, 2015 04:38 PM
mddaniel
Sep 8, 2015 05:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
