can i supercharge my 355?
Old Jun 13, 2007 | 01:41 PM
krogmister16's Avatar
Car: 88 firebird formula
Engine: 305 tpi
Transmission: 700r4 with shift kit
Axle/Gears: 3.73 with eaton locking diff
ive god a 4 bolt main 355. its got a gm forged crank, powdered metal rods and forged speed pro pistons. its got solid flat tappit cam and 64 cc world products sportsman 2 heads with dual springs with 9.5:1 compression. i should be making between 400 to 500 hp. can i get away with running a supercharger with my bottom end? im going to have a edelbrock victor jr intake, do u know any twin screws that will fit on that type of intake? thanks seth
Old Jun 13, 2007 | 05:11 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: can i supercharge my 355?
what cam is in it ? If you are makeing 400-500 hp ( ummm not to sure about that ) ...then most definately you will need a new cam . also that intake will not work ...if you are bolting on one of them type of superchargers
Old Jun 13, 2007 | 08:43 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Your bottom end will hold all day long...
Old Jun 13, 2007 | 10:15 PM
Engine: 305 tpi
http://www.hotrod.com/techarticles/w...est/index.html
on this article they say they use a Edelbrock Torker II Dominator manifold for the twin screw supercharger. do u need to do any fabrications to the manifold for the supercharger to fit on there? what kind of cam are u suggesting me to use? im using a bracket master 2 cam.
Advertised Duration IN/EX: 300/310
  • Duration @.050 IN/EX: 256/270
  • Gross Valve Lift IN/EX: .500"/.515"
  • Lobe Sep Angle / Intake Ctr Line: 112/108
  • Valve Lash IN/EX: .028"/.030"
  • RPM Range: 2500-6500
Old Jun 14, 2007 | 11:41 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
How do you figure 500 hp??? With what you mentioned, you must have some serious heads and pistons, as well as ignition to get those numbers. Can you elaborate a bit on your current combo?
Old Jun 14, 2007 | 04:31 PM
Engine: 305 tpi
i said between 400 to 500. not 500. a guy that i know works at wegner performance in wisconsin said i can make those numbers with alittle work the the heads. i dont have the whole thing put together. can you tell me a good head and cam combo for a charger? thanks seth
Old Jun 14, 2007 | 07:21 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
400 is even optimistic. As a baseline anyway. Your probably gonna end up making around 300, with the combo u mentioned
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
-=Z28=-
Sep 24, 2015 10:21 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
