Nitrous Jetting
Old Jul 3, 2007 | 11:39 AM
kronos's Avatar
Car: 89RS
Engine: Lo3 bored.030 over, 230/480comp cam
Transmission: 700r4 10" converter
Axle/Gears: Stock G80 2.73
Nitrous Jetting
If I am running 6psi of fuel, what is the proper jetting for a 75 shot?
Old Jul 9, 2007 | 04:44 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Nitrous Jetting
with 900+ psi and using a plate system or single fogger nozzle it would be 36 Fuel, 44 nitrous. This is for 75hp rated at the wheels
Old Jul 9, 2007 | 05:11 PM
DIGGLER's Avatar
Re: Nitrous Jetting
how about when running 43# fuel pressure with a plate system? thats what i have... is there someplace online where i can go to pick out jetting based on my fuel pressure and plate setup?
or, what would you run for a 150, 175, and 200 shot?
Old Jul 9, 2007 | 09:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Nitrous Jetting
cann your nitrous company as each numbers their jets differently.
Old Jul 10, 2007 | 10:16 AM
Car: 91 z28
Re: Nitrous Jetting
150: 35 F / 63 N
175: 37 F / 68 N
200: 40 F / 72 N
http://www.robietherobot.com/NitrousJetCalculator.htm
Old Jul 18, 2007 | 09:45 PM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Re: Nitrous Jetting
well every company rates their jets a little different for example my 150 shot is a 70 jet a 100 shot is a 52. Nos plate kit #5151.
Old Jul 19, 2007 | 03:59 AM
Car: 91 z28
Re: Nitrous Jetting
that all depends on the fuel and bottle pressure they use to rate the "shot" and if they are doing it at the wheels or the flywheel...if they all have the same constants..no kit should differ in jetting size as they are all essentially the same parts, one solenoid doesnt effect the shot any different than the next.
69GTOby
Apr 18, 2016 02:34 PM
anesthes
Sep 18, 2015 12:34 PM
mackjar66
Sep 14, 2015 01:17 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
