Looking for a blower
Old Jul 24, 2007 | 09:42 PM
camarodude87's Avatar
Car: 92 rs camaro
Engine: supercharged 355
Transmission: t-5
Axle/Gears: 342
Hey guys
I just recently built up a mean 350. the compress is 10:1 and i was wondering if I could thrown on a blower. I was told that I couldnt and is there a way that i can lower my compress if thats the case
thanks Ray
Old Jul 24, 2007 | 09:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Looking for a blower
This should be in the power adder forum.
To lower your compression, you can install new heads with larger combustion chambers, you can install new pistons with a bigger dish, or for a minor change you can install new head gaskets with a larger compressed size.
You can put a blower on practically any engine. How long it will last is a function of how strong the parts are in the engine.
Old Jul 24, 2007 | 10:42 PM
92 Formula's Avatar
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Moving to power adder forum.
Old Jul 25, 2007 | 01:36 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you can throw a blower on there, just expect to run race gas..
Old Aug 4, 2007 | 03:09 AM
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
https://www.thirdgen.org/forums/engi...v1-s-trim.html
codeysabatini
Nov 10, 2015 04:07 PM
86IROC112
Sep 28, 2015 08:17 PM
buckeyecelt
Sep 24, 2015 05:50 AM
soarestransam
Sep 1, 2015 04:00 PM
mhatfield 14
Aug 15, 2015 10:47 AM
