Vortech filled with grease?
Old Sep 30, 2007 | 07:39 AM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
What are thoughts on filling my vortech supercharger with grease instead of pumping oil.
Old Sep 30, 2007 | 08:19 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Vortech filled with grease?
i would say that would be a bad idea, it may not be as viscous as the reccommended oil and may also be too thick to allow the gears to turn properly. also, unless its a self contained unit, it uses engine oil for lubrication
Old Oct 7, 2007 | 11:10 AM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Hello,
All Vortech's use engine oil injection - any thing else and you will burn up the drive gears as the smaller gear turns at around 20K rpm at times.
It's easy to use an oil filter sandwich plate with taps for oil supply. Run an oil line from the sandwich plate to the oil injector on the side of the blower - I seem to remember that the oil injection fittings are -4 an, and the oil return are -8 an. Out of the bottom of the supercharger run an oil return line back to the pan. There are several companies that make an adapter to mount to the pan for an oil return port.
Have pfunn,
Ed.
Old Oct 7, 2007 | 11:56 AM
Guest
Guest
Posts: n/a
Not to mention it uses the oil to cool the unit, and thats constantly refreshed by the engine. Put anything else non-moving in there and you'll just burn it up.
Old Oct 10, 2007 | 06:36 AM
Engine: 400 and 350
Thanks for the help.
Old Oct 10, 2007 | 11:14 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
There was one turbo designed as oil-less. It was made by Aerodyne. It didn't last. An SC or TC needs a constant fresh supply of oil.
meeklay812
Oct 1, 2015 03:46 PM
anesthes
Sep 30, 2015 07:48 AM
HikoriYami
Sep 21, 2015 07:11 PM
corey8084
Sep 17, 2015 02:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
