Kaiser Roto-charger on my Trans Am
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: Kaiser Roto-charger on my Trans Am
If I posess the abilities to turn my corvette into a convertibe and a factory looking one, why would it be so hard for me to make a bracket and weld sprockets on something? ..... Seeing is believing yes but just cause you've never seen it doesn't mean it doesn't exist now does it!
I said it was an impossible task, to refer to nobody ever doing it and nobody would think of it, besides yourself. Making a non-existent thing and making it into a existent object.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Look at mcmaster carr, or other power transmission companies. There should be a pre-built component ready to use (talking about the u-joint type coupler).
I've seen some misalignment shaft type setups that use a rubber joint, but they are only rated to a few HP max. If you slot holes to mount the blower you shouldn't need any misalingment devices.
And as of now, its 2am on December 2nd. He OBVIOUSLY has the means to have taken pictures of SOMETHING.
I vote for ban.
All in favor, post the term "Ban."
I see Santa will have a couple less stops this year ..... It's the time of the year to be Merry !!!!!!!!!!!! I wouldn't count on the Easter bunny showing up either !!!!!!!! ...... You will all see when I achieve greatness and cause sale to dwindle over at other well known makers of superchargers and I become the next howard hughes ......
Well when my car is finally finished you will be apologizing and be left in pure amazement as I show you a 90.00 supercharger that can crank out as much boost as a well known one. I would have to say from my last race with my friend my car now is good for maybe mid 13's .... show me another 100.00 mod that will make your car 1 second quiker... in a race I used to be behind about 1 to 1 1/2 car lengths behind this 1990 corvette. In our last race I had a good 9 car legths on him and he wasn't cathing up and this was after going from 3.73 gears to 3.08 gears in my car.
Car: '82 Z28
A used nitrous kit. Till you post pictures of this frankenstein setup, you will be a liar to me.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
I just wasted a good 1/2 hour of my life reading all 108 replies to this thread...
Lets wait till he at least admits to having the car at his house again. If then no pics, well I am a non believer.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
the next vacuume gauge that I had reade -30vacuume and +30psi.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ick man what is that dried man jiz? I'm actually being serious what is that gunk?
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's a paint stick. They're great, they write on anything. I'd avoid the use of profanity or insults guys, I don't want this thread to be locked before the pictures arrive.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
understandable and sorry. it was just that was the closest thing I could think of it looking like.
but I'm with you on thinking this doesn't exist. sure a rotary based supercharge would work, and that was what the original design of a rotary was used for but I don't know how well it would work.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
not really, and if they already have the trans out it becomes even easier in my opinion, same with the rear main. I did say if they were actually working on your car and not just letting it sit there until they can get to it.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i've got like 3 turbos on my car, its super cool and stuff...
Now sing along with and I'm sure you'll remember this quote from the old days ...... however I added my personal touch to it.
Baseball --- Apple pies ---- Chevrolet ---- Kaiser
Heck my uncle Oloff has a bunch of these in his shed. Maybe I will become americas newest Icon ... Heck I see these having awsome potential on ebay. You know If I could mass produce them, I would be in the fortune 500 in no time.
That was just nasty to even post that .... very poor taste ......
I can build one for your car too!!!!!!!! ..... Course it will cost you a good chunk of change to have something on you car that is built by me. But hey you;de have that great smile whenever you blow by corvettes.
Food for thought.
Car: 91 Camaro
I didnt mean to insult you or anything...I was just trying to illistrate the fact that anyone could just make claims about what they "did". Im not saying you didnt or shouldnt have. Im all about going down the path less traveled(to an extent). I just want to see some pics of it.
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Well atleast this was slightly entertaining...
But its definitely BS.
Car: 86 Trans Am
i will bet 10 dollars paypal that you wont post batch of pics of this contraption and its workings SOON.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
well in his favor on this one I have seen people convert a non-convertable to a convertable. usually though it ends up causing problems down the road as the whole scructure of the car is different for a convertable since that top part is a very important part of bracing.
part of the reason why convertables weigh more then a non-convertable. it's due to all the extra bracing that is required that ends of weighing more then jsut the hard top alone would of had.
EDIT: though I'm assuming your not refering to that part but rather the kaiser supercharger part. oh well.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Car: 1982 Trans-Am
$10 to snap a few pics sounds pretty fair.
I'll match it - a gentlemans word (digital handshake?)
You have until wednesday at 5pm Pacific time. If there are pictures up that convince us this has actually been built, myself and 86TA will both paypal you $10 USD.
Who wants to chip in for this? A couple people tossing in $5/10 and you'll have the thing paid for!
If not by then, i'm out. How's that for fair? 86TA, you in?
Car: 2005 BMW 545i
Engine: 4.4L N62B44
for some reason I'm thinking your someone else just having fun.
you don't by chance know a driver by tha name of mason, and your boss beign bob and tom are they?
if I'm wrong that's cool no biggie.
Wow !!!!!!!!!!!!!!!! how did you guess it was me???????
Gentlemen & ladies (if there are any women reading)
Please lets stay on topic ... That being my supercharger .... If this thread gets lock I will not start another one .....
So lets keep the topic clean and stop the personal attacks .... If the thread does get locked you will all lose valuiable information to make power cheaply and easily.
Nice, thanks for admitting to being a total fake. Although we all already knew that this was fake. But Entertaining atleast.
Car: 1982 Trans-Am
Nah, I don't think paying for information or pictures is illegal in anyway, or against the board rules actually.
I think you've just lost your last shred of credibility. Looks like no one is willing to give you any help or advice on your mythical creation, so what's the point of this thread anymore?
You don't have any questions anymore do you?
Might as well let this thread die then....
Car: 2005 BMW 545i
Engine: 4.4L N62B44
eh I'm not so sure anymore that it is who I thought it was. if you don't mind me asking what is your occupation?
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
If $10 wont get you off your A$$ to post a pic I got $100 paypal that says this is all bull $hit and I am sure other members would put up some money because they know its BS too...Post a pic or let this thread die!!!!!!!!!!!!!!
$10 from me is thrown in the pot.
If he does post the pic by then, he gets $130 and counting.
Sonix - $10
86TA - $10
4playta - $100
Myself - $10
If he doesnt, ban hammer-time.
Sonix - $10
86TA - $10
4playta - $100
Myself - $10
Ban me for what? ...... I haven't said anything offensive to anyone nor suggested anything offensive!
Most of you on the other hand. Well, thats a different story.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you are so full of male bovine fecal matter . your profile says that you are part of the i.r.s. . does that mean , internal rectal search ? i think that your head may be in that area . hope you find where it is soon ( i think the rectal area is a good place to start ) HOPE THIS THREAD GETS LOCKED OR BANNED .
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
From reading almost all the treads on here i can see that you are pretty much the biggest liar on the face of the earth unless proven wrong by you posting some pics of it. If this contraption some how works. Im not sure you would just go to the local auto parts store for parts that break.
Im sure you beat a corvette to.
I forgot to say that my lo3 camaro does 200 mph in reverse. Nother BS story
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
i think we should make a pilgrimage to behold this mighty accomplishment, put an image of his contraption on the back of $5 bills. maybe even erect a monument or give him a holiday to his credit... cause this line of shzit if far better and entertaining than what weve been subjected to for past almost 8 yrs.
i tell you what master of masters, pioneer of mythical power adders, king of fecal literature, rival to the gods!
I! will start the revolution to dawn your accomplishments in the light of TRUTH!...
after i have lunch with sasquatch and santa tommorw.
Engine: TPI 350
Transmission: TH350
Ya im sure you made all that bs you said. till you post pics nobody in the world will believe you. It takes good gearing not sails. And its only 1 gear. Oh ya my 0-60 is 2 seconds 2. bett you didnt know only my camaro came stock with 800 hp. rare deal. Why do you still go on with this.
please
