Video of 305 on a 150 shot
Old Oct 30, 2007 | 08:01 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
I ran out of gear in the 1/4, which don't bother me much because I don't live very close to a 1/4 mile track. There are 3 8th mile tracks within an hour of my house.
Old Oct 31, 2007 | 01:37 PM
mlaudon's Avatar
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
Re: Video of 305 on a 150 shot
Thats pretty good. I have always wondered what a kinda stock 305 with a 150 shot would be like. Now just think if you just put a little but of money into a 350.
Old Oct 31, 2007 | 02:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It wouldn't go all that much better.
Old Oct 31, 2007 | 02:41 PM
SLP_GTA's Avatar
very cool vid, sounds very heathly for a 305. Thanks for sharing
Old Oct 31, 2007 | 03:57 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
I will beat on this thing till it blows. I am going to up the shot 50 hp each time I take it back to the track (if the plate will flow more than it is now) Then I will put a LT1 in it that I have.
Thanks and your welcome.
Old Nov 6, 2007 | 04:52 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
What all have you done to the 305?? I just sprayed 150 shot to mine. https://www.thirdgen.org/forums/powe...s-nitrous.html
Old Nov 6, 2007 | 05:38 PM
funina91ss's Avatar
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Originally Posted by chevymec
What all have you done to the 305?? I just sprayed 150 shot to mine. [My best run on motor was 14.77@83.01. On the gas was 13.1@103.21]
I have put mac shorty headers and off road y pipe. Edlebrocke tbi intake K&N open air filter. and a used compu cam. (don't know the specs but it's very small) Had the car tuned and spraying a 150 shot on it.
You can tell how much I ran out of gear in the 1/4 your 13.1 pass was at 103 I went a 101 with the 12.49
Good luck on getting your tranny fixed and get it tuned for the spray. Mine was way rich when we first started messing with it going by the jet chart.
Old Nov 26, 2007 | 12:01 AM
shinobi-x's Avatar
Car: 69 chevelle & 84 corvette
Engine: L83 350 & 355/142 Blower
Transmission: 700R4/ATI TH-350
Axle/Gears: 3.07D36/3.73 12bolt
305 + 180 shot in my buddies 82' camaro.
Old Nov 26, 2007 | 03:00 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
cool good job all of you sticking with 305s and doing nitrous. they all looks good and perform good. last video is awesome badass 305 for sure.
Old Nov 26, 2007 | 04:56 PM
shinobi-x's Avatar
That 305 wasn't stock either, ED Rpm heads Comp NX 240/253 @.050 cam,1.5 full rollers,Victor Jr. intake,Mighty Demon 750 mechanical carb,Hooker headers,3.5" exhaust into a 3" flow at the end. 3.70 gears in a 9 bolt with 255/50R16 drag radials.
P.S. it was set-up for nitrous and rings gapped accordingly with the 305. Its a buddies car,it now has a 355 with the same components ie. rods,rockers,cam,flywheel and with a single 250 shot and Brodix heads/intake. Everything else is the same and the same cam too!
Old Nov 27, 2007 | 08:31 PM
Engine: LO3
yea i figured as much
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
perZ
Aug 21, 2015 05:51 PM
Sanjay
Aug 12, 2015 03:41 PM
