This is semi theoretical, but can I piece togeather a rear mount turbo 4 around $1K?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Well the tittle says it all. I am happy with the power my car makes for the most part. I am getting a new cam and slapping on an RPM air-gap real soon to help bring the power on a little earlier. I also have about $1000 I "may" be able to spend on other stuff. If I get a used/rebuilt GOOD turbo do you guys think I can get my car running with a few PSI (less than 6) for less than a grand?
I can weld and piece togeather pipes and stuff like that. I have a LARGE fuel supply and have a 4" exhaust. My internals are all forged and I have Al. heads. Comp ratio is around 10, but I am not 100% sure. motor is a hydrolic roller 386. Carbed. My grand doesn't include the price of modding the carb.
I can still buy a different cam if need be since I am swapping that out soon.
I just want the adjustability and added power of the turbo without changing my headers and so on.
Can I get a cheap oil pump? What have people run in the past to do this? Lines are cheap and so it piping. I am talking non-intercooled since it is very low PSI. I just don't want to rip into the motor at all. If I have to, i am not going to even bother with the idea.
I would only consider running a thicker head gasket. Car has a booste ref reg. and 8- AN feed lines.
Possible or no?
Possible or no?
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: This is semi theoretical, but can I piece togeather a rear mount turbo 4 around $
when it comes down to it, you really dont want to cheap out on this sort of stuff. Depending on what turbo you want, you would be spending a good portion of the money on that and the carb would take up damn near the rest. Your t-56 should be fine with just 6 lbs of boost as long as you dont abuse it all the time.
What about running spray and pocketing the rest of the money?
Engine: LS3
I have spray right now. I have only played with a 100 shot but the motor can take up to 300 around there due to the forged internals. I have a 200 shot I am going to play around with on the dyno in a couple weeks to see how that it. But in the end I would like to have something a little more permanent.
It is all theory, i would rather just keep the $ in the bank, but if someone said, "yeah, you can get a nice turbo for $500 and a an oil pump for $100 and $300 to mod your 750 Holley DP" Then I would strongly consider the idea.
If the cost of all these things are going to be that x2, then forget it and I will play with spray for a few years while I want to get out of school.
The car makes 344 RWHP and 340 RWTQ. (N/A)
i kinda want something more like 400-450. So I really only need a little booste. 6 is probably too much. can't I get a turbo from a SAAb or something and make a few PSI?
Oh and this is a 100% street car. I drive it to work everyday. Comes off the road in the winter.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
in short no....keep the nitrous, and your NA friendly cam and play around with that. a dual plane intake isn't boost friendly either, if you had a vic. jr or similar then maybe, but that 4" exhaust isn't what you'd want either. Stick with what you got and send me half the $$ you would have wasted and we'll call it even.
Car: 1984 z28
Engine: BBC
Transmission: TH400
a saab turbo is as big as your fist, it would choke your power up top, especially mounting it in the rear with that 4" exhaust. With 6 psi and a decent turbo you might see 400. Personally, I wouldnt do it, but you could. I'd personally take advantage of those forged internals and get a bigger cam, and better intake manifold, you would be much happier with those imho.
Engine: LS3
I have a HUGE cam right now. it is too big acctually. The thing has a very choppy idle and I make only 9" of vac at idle. It is a 246/254 duration cam. I am going with a 230/236 duration cam next and swapping my vic jr. for a RPM air-gap. I want to make this thing more streetable but don't want it to loose its *****.
I figure setting up the N20 to run prefect will be fun to do. I dunno where I am going to use it though, haha. I tried it once on the higway, going from 70-90 for a few seconds. That was fun. I want to try and use it down low though.
My car feels very fast when it is spun up, I want it to feel that fast with less RPM, thats why the smaller cam and dual plane.
i guess the small turbo idea is strupid. Forget it. I will save the $ and toss it into the " down payment on a house" foundation.
Then later down the road I will build an LSX or something.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
