ram air or cold air
Old Dec 26, 2007 | 01:12 AM
Fire&ashborn's Avatar
Car: 86' Firebird
Engine: 2.8L V6 fuel-injected
ram air or cold air
which is better..i have the option to put wthier or on my car..wats best?
Old Dec 26, 2007 | 10:57 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Re: ram air or cold air
I personally like the cold air. I was going to go with the ram air hood for the look byt use the cold. I decided not to cause my car looks perfect the way it is.
Old Dec 27, 2007 | 08:38 AM
Damon's Avatar
Well, ram air technically is cold air with a plus. But ram air doesn't really do squat until you're up around triple digit speeds. Cold air helps all the time.
Old Dec 27, 2007 | 02:58 PM
Car: 86' Firebird
aiight thx..i just dont want my car to overheat or sumthin n **** to start goin wrong
Old Dec 27, 2007 | 06:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
on a v6 neither will help "much" This is money that could be put away for a future v8 swap or sell your vehicle and purchase a v8 equipped car.
Old Jan 7, 2008 | 02:38 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
WEll yes if it is the v-6 you shouldn't use too much money as the motor won't see the gains you were hoping for. The Ram Air hood with air intake is a cold air set up but the down fall is the air filter element is open to all of the elements so it becomes adry weather car only and needs extra care during washes.
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
jimmy harris
Aug 31, 2015 03:09 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
