Turbo Header question
Old Jan 9, 2008 | 08:29 AM
jonarotz's Avatar
Car: 91 Z28
I am building some Turbo headers for a twin turbo setup and was planning on using 1/2" thick mild steel header flanges and 304 ss plumbing els. My welder advised me to get stainless header flanges. He mentioned that welding stainless to mild steel would be possible but was worried about it cracking. What do you guys think, will I be alright with my original plan?
Old Jan 10, 2008 | 12:36 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Turbo Header question
You can get S/S filler for S/S to mild steel. Back purging or Solar flux would help make a better weld. I would not weld S/S without either of the two. If it was my setup I would use mild steel flanges. Have you asked the fab person about possible expansion problems with S/S flanges at the head?
Old Jan 10, 2008 | 09:48 AM
jonarotz's Avatar
Car: 91 Z28
Thanks, I passed on your comment to see what he thinks. I wanted to keep with mild steel flanges just for the heat expansion reason.
Old Jan 10, 2008 | 12:05 PM
jonarotz's Avatar
Car: 91 Z28
After discussing it with my welder, we are going to use the steel flanges and use 309L filler rod.
Old Jan 10, 2008 | 12:15 PM
junkcltr's Avatar
Engine: 3xx ci tubo
That is the way I would do it, mild steel flange and 309L filler with Solar Flux B or argon back purge.
Old Jan 12, 2008 | 04:07 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I used 312 filler rod, seems to be holding up just fine.
Street Lethal
Apr 30, 2019 12:14 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
