142 on gm performance 330 ho
Old Feb 11, 2008 | 12:02 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
I'm new at knowing dry roots blower basics, so don't be to rough on me. As you read by my title I have 9.1 vortec engine with the 435-460 lift cam. I don't want to switch to hyd cam for better breathing and better springs and lifters for stability. Using my exsisting confiqurration how many pounds of boost can my engine safely handle? I've read 5 pounds will take compression up to 12to 1. Would I need a boost retard ignition?
Old Feb 11, 2008 | 01:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 142 on gm performance 330 ho
What?!? I'm lost.
I believe you already have a hydraulic cam. Clarify what you mean by your cam statement.
You have what, 9:1 CR? You can do 5psi of boost on a roots blower without too much hassle, especially if you cam it up a bit. Boost retard on your ignition is a very good idea.
Old Feb 11, 2008 | 04:15 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
I meant to say I didn't want to switch to hydraulic roller cam. Sorry for the confusion. As the valvetrain is, will it hold up to 5 pounds boost.
Old Feb 11, 2008 | 04:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Boost has very little effect on valvetrain. You'd need upwards of 20psi of boost before you'd even need to consider upgrading valve springs to fight the boost pressure.
Old Feb 11, 2008 | 04:45 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
thank you very much and heres a interesting article on a vortec blower
http://www.popularhotrodding.com/ima...350/index.html
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
