k-member with martin kit
Old Feb 23, 2008 | 09:01 PM
Marc Brown's Avatar
Hey , just thought I'd tell you guys , I finally got to see if a Martin kit fits, well it does all the way till the turbo manifold... I have a 88 formula and I think it will work... the strut tower braces are not a problem with this unit.. there is about a 1/4" inch from turbo to tower clearance... no problem there... well the driver side original manifold works great for this application, so does the pre-86 manifold... anyway... the turbo's manifold of coarse fits, but I looked down and seen the brake line there and it looks as if that might have to be moved.. still one problem , the k-member... I think I can put half of the crossover pipe in when I put the turbo's manifold in , looks like I could half the pipe and join in the middle of the crossover... 2 of the bolts I can get to from bottom , the other one, (which would be hitting the brake line if not moved), is the one I can't get to from below.. k-member in the way... what do i do? put the pipe in when I do the manifolds or put a allen head on that one bolt ... I thought about beating the pipe in ,in that area... would I need to move the brake line then or just beat the pipe some... It is a crossover pipe.. , oh and one more question, on a turbo setup like this with a crossover pipe, could you use a shorty header on the driver's side manifold or would this cause a flowing issue... It's all going out the turbo anyway? Just thought I could at least help this setup out some... just let me know what ya'll think.. I really like the looks of this old setup, easy on the pocket also... I'm open for any suggestions or comments... good or bad... I know it's old , but you just don't see these setups anymore(probably for good reason) I know racer rick on the turbo forums.com has this setup and got 353 RWHP... not bad, thats about as much as I want in horses... so if anybody can help me, please let me know
Marc
Old Feb 27, 2008 | 07:52 PM
Marc Brown's Avatar
Re: k-member with martin kit
https://www.thirdgen.org/forums/atta...1&d=1204163226
just thought I'd show you guys the mock up of this Martin kit and I found out how to miss the k-member.. I just moved my flange of the exhaust manifold up about 2 inches... everything fits great now... the tower is close but it has about 1/2 inch clearance.. not much , but I'll definately be getting poly mounts... and by the way, don't look at the engine bay.. Thats a blown 305 and the body is getting bodywork done, just trying to mock up while engine is in bay... and before I put the stand motor in , it will be all smoothed out and painted... anyway... This kit is snug , but I kind of dig the way it looks... anyway
Thanks for looking
this is my first time adding a pic to any website , so the size might be crazy
Thanks again
Marc
Old Feb 27, 2008 | 08:22 PM
Marc Brown's Avatar
https://www.thirdgen.org/forums/atta...1&d=1204165240
KR sized 2 turhttps://www.thirdgen.org/forums/attachment.php?attachmentid=152388&stc=1&d=1204165262
Just trying pics again.. but here are a few more.. sorry about the fuzzy one... camera wasn't set for sport..sorry..anyway.. thanks for letting me try some pics also... anyway... comments would be great...
thanks
Marc
Attached Thumbnails k-member with martin kit-kr-sized-2-turbo   k-member with martin kit-kr-sized-photos.jpg
Old Nov 29, 2012 | 09:05 PM
Marc Brown's Avatar
It's been awhile since I've posted I know, but here is the Martin Turbo kit in my 88 Knight Rider replica....and yes, after modding the exhaust manifold, it will fit. You have to also get a Mini-starter, but after that, that's it....turned out cool.... I have 12V at cap, and have heard it turning over , so.... timing is done, and yes, now time for the accessories... Later
Marc
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Mdenz3
Sep 17, 2015 08:36 AM
funkyTA
Sep 10, 2015 06:38 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
