Crankcase evac for 10psi worth the trouble?
Old Mar 15, 2008 | 07:44 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I've been thinking about hooking up an exhaust evac system. Im running dual x-pipe 3" with dynomax welded mufflers. I've heard the evac systems dont work too well with mufflers.
Running around 10psi, I was thinking about just going off one valve cover, and leaving the other side vented.
Worth my trouble? The engine is new, so its tight.
Old Mar 15, 2008 | 08:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Crankcase evac for 10psi worth the trouble?
the type where it exits into the exhaust would just cause a restriction and cause oil to push out of various areas of the new engine. The only thing extra you could run would be a vacuum pump.
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
