adding most horse power
Old Mar 27, 2008 | 10:06 PM
spddmn's Avatar
Car: 92 camaro rs
Engine: 305 5.0 v8
Transmission: stock automatic
Axle/Gears: stock
i have a 92 camaro rs with 5 liter v8, what would be the best way to add the most power you can get out of the engine
Old Mar 27, 2008 | 11:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: adding most horse power
Nitrous. Easiest and cheapest.
Read what this forum is specifically about though... If you're not going for that, then I think you want to be in the tech/general engine, or the TBI forum.
Old Mar 28, 2008 | 01:46 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're in the wrong forum. This forum isnt for adding power to an engine, its about putting a power adder on an engine, such as nitrous, turbocharger, or supercharger.
You should probably check out the TBI forum, and read the two "Ultimate TBI" tech articles.
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
