how much of a "shot" will 4AN handle?
Old Apr 1, 2008 | 04:47 PM
chevyboy07 91's Avatar
gents, i am running a dual stage, but am feeding both stages with one bottle through a 4AN line. I am running a TPI plate system from NOS.....with the regular/pee-wee solenoids....wet...also runing a single fogger nozzle drilled straight into the front of a K&N TB mounted air filter..also wet.....using another set of pee-wee 'noids. so, the noids will do 150 each....but I dont think the 4AN line supports that.....comments??
My set-up is jetted for 150/75 HP for a total of 225 on the 1st and 2nd stages right now....is it happening or not?
Old Apr 1, 2008 | 07:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: how much of a "shot" will 4AN handle?
I'd be buying bigger solenoids and building a kit that can spray more, that design is just asking for trouble with 2 separate nozzles on the engine.
Old Apr 2, 2008 | 01:49 AM
can you clarify as to why??
and specifically, can you answer the original question?
again, one is a plate on the TB the other is a nozzle in the filter.
1. how much will a 4AN line support.
2. I have seen 16 mph increases on the spray.....approx how much additional power do you think that is?
Old Apr 2, 2008 | 10:51 AM
xpndbl3's Avatar
Car: 1984 Z28
fuel distribution issues for one. call the nitrous company and ask about how much of a shot it will support, I ALWAYS just put in a -6 nitrous line and forget about worrying about it. Those little solenoids aren't as reliable on bigger shots as for instance the NX brand larger solenoids.
Old Apr 3, 2008 | 08:25 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
250hp that dont mean your car wont make a little more pwer with a -6 at that point
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
roysatikas
Sep 22, 2015 08:15 PM
apie2546
Sep 20, 2015 01:03 PM
