need advice for turbo size.
Old Apr 7, 2008 | 12:35 AM
Mr.K's Avatar
Car: 1982' camaro Z/28
Engine: lt-1 out of a 95' impala ss
Transmission: viper spec t-56
Axle/Gears: Ford 9in 3.90 gears
im am going to be building a 383 and am planning on doing a rear mount sts style turbo set up. my question is what size turbo should i go with? my combo is going to be a forged bottom end 383 lt1 with ported factory heads and probably around 8:5.1 comp.
Old Apr 7, 2008 | 07:24 AM
Reputation7's Avatar
Re: need advice for turbo size.
S400.
cheap + all the power you could ever need.
Old Apr 10, 2008 | 09:54 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Originally Posted by Reputation7
S400.
s-400 is a terrible idea on an STS setup with its t-6 housing and 1.23 A/4, not to mention the size of it. You should look at something in the range on a t-76, though you could get away with something like a MP t-70 with the .96 housing (t4 flanged) to help with spool.
Old Apr 10, 2008 | 05:34 PM
take a look around ls1 tech and look at the 90+ mm rear mount setups currently being used.
s400 is not too big.
you could have a good spool too, wrap the exhuast all the way, etc.
no green
Mar 3, 2016 05:19 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
tgp1990
Sep 4, 2015 06:24 AM
mrdevontay
Sep 2, 2015 08:04 PM
