Best pistons
Old Apr 17, 2008 | 09:22 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
Best pistons
I read that it can be hard to push an l98 to 400hp with the stock cast pistons, so I was wondering what would be a better choice, some hypertuerics, or some forged?
Old Apr 17, 2008 | 09:30 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Best pistons
forged or course. What kind of power adder are you looking to go with?
Old Apr 17, 2008 | 09:37 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Re: Best pistons
Very soon Im going to be finishing a tbi to tpi swap, just need the injectors and tuning now, but I was thinking of a procharger. How much trouble is it to change pistons?
Id like somthing strong enough to hold up well with 7 or 8lbs, and I dont want to buy injectors or bother with tuning until I know how much fuel its going to need and what kind of chip is required.
Last edited by camshaftxe; Apr 17, 2008 at 09:42 AM. Reason: Automerged Doublepost
Old Apr 17, 2008 | 10:08 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Re: Best pistons
Forged would be best.
I would go with Diamond for your piston brand. I have them and love em.
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Best pistons
Speed pro makes nice cheap forged pistons, might be worth looking at.
You need to remove the engine from the car and have it on a stand and completely disassemble it to change pistons. Are you getting in over your head here?
Old Apr 17, 2008 | 10:20 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Re: Best pistons
Yea, I dont have the working area or tools to remove the engine
How do the stock pistons hold up to 5 or 6 lbs? Is it true stock cast pistons dont hold up past 400hp?
Last edited by camshaftxe; Apr 17, 2008 at 10:22 AM. Reason: Automerged Doublepost
Old Apr 17, 2008 | 10:26 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Best pistons
Yea, then you're over your head.
No that's not true. It's not that cast pistons are weak, and explode or anything, it's that they shatter from detonation easier than forged pistons. Don't let it detonate, then they're fine.
Old Apr 17, 2008 | 10:47 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Re: Best pistons
Does n2o have the same effect?
Old Apr 17, 2008 | 11:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Best pistons
Yes, N2O is hard on pistons, but a 150HP shot is barely worth writing home about. People put that on stock pistons often. 200HP + is where you want better pistons, bigger ring gaps, stronger rods, etc.
Old Apr 17, 2008 | 11:53 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Re: Best pistons
So do you think I could achieve 400hp with a mild build and a 75 shot? When I say mild build I just mean with my current mods, subtract tbi, add a ported tpi.
Old Apr 17, 2008 | 12:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Best pistons
No idea what your current mods are.
Port up the heads and put in a cam. Don't use a stock TPI intake, use a superram or something. Then yes, 400HP as is. You won't need the 75hp shot for that.
Old Apr 17, 2008 | 12:42 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Best pistons
If you go N2O make it wet.... you'll be really upset with a dry 150 shot. Just throwing that out there.
Old Apr 17, 2008 | 12:57 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Re: Best pistons
L98 shortblock, .040 bore, 160 thermo, underdrive pully, a/c and emissions delete, true dual 2.5'' no cats, 2 arochambers, hooker shorties, xe262 cam, walbro 255 inline, and tbi induction for now. The tpi will consist of a ported tb, a coolant bypass, ported plenum, ported base, and an afpr.
Old Apr 18, 2008 | 09:23 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Best pistons
You'll probably be pushing 300-320HP at the crank with that. Port the heads, upgrade to aftermarket intake and maybe cam it up a bit. Use a roller cam in a roller block man, like what the heck eh?
You've got another 40HP locked in the head porting and intake upgrade there. A lot cheaper than filling a N2O bottle a few times.
Old Apr 18, 2008 | 09:39 AM
81caballero's Avatar
Re: Best pistons
carefull when porting the L98 head, they are very very thin. look at mahle for forged pistons, they are decent price and are forged. they come with moly rings already installed. just make sure you tell whoever machines the block that you are running moly rings, they need a different crosshatch finish for seating.
Old Apr 18, 2008 | 06:14 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Re: Best pistons
The cam is a roller, and Im pretty l98 blocks are hydraulic roller, and I didnt mention but the heads are 093s. Im considering going with a edlebrock tpi intake kit, but I dont know about the edlebrock runners, does anyone recomend them?
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
