nitrous question, havent seen this ? before
Old May 7, 2008 | 09:55 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
ok so lately i upgraded my tbi nitrous kit to run on my tpi conversion so i bought a single fogger and used the rest of the kit. anyways i put my fogger in my firebirds intake boot right in front of the throttle body but its towards the drivers side more. my question is will this cause uneven distribution or will it work fine? also my thinking is the air is rushing so fast and the passenger side runners are before the drivers side so it actually might even the flow out even more if it was centered. this is a NOS fogger 2 nozzle i believe which is suppossed to have a better more fine spray pattern. i also have a throttle body airfoil which i think will also let it still flow a bit to the passenger side. but heres a picture of how it is and ill be running a 100-150 shot on this.
thanks in advance guys i always have success with this site.
Old May 8, 2008 | 09:03 PM
Engine: LO3
Re: nitrous question, havent seen this ? before
nobody? im about to just try it as is saturday and hope all is well i guess.
Old May 8, 2008 | 09:19 PM
Finetunedz28's Avatar
I ran a similiar setup years ago. Mounted mine underneath on the boot. Went a step richer on fuel side. Should work fine. Only issue I had was hitting it from a dead stop. Worked best from a roll.
Old May 8, 2008 | 11:53 PM
Reputation7's Avatar
you scandalous ho.
***** gonna lean out the cyls on the right bank. sry.
this is what you shoulda did.
Old May 9, 2008 | 06:51 PM
Engine: LO3
finetunedz28 ive run nitrous and know how it reacts ive done it from a dig and roll but i got that under control. my question is youre dead center underneath or off to one side?
MustangBeater20
Oct 29, 2022 09:20 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
