just a quick carb nitrous question
Old Jun 1, 2008 | 11:45 AM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
Where do I connect the fuel solenoid? Before or after the fuel pressure regulator? thanks!
Old Jun 4, 2008 | 01:11 PM
RaGiN Z's Avatar
Car: 83 Camaro
Re: just a quick carb nitrous question
nobody eh?
Old Jun 6, 2008 | 11:59 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
How do you have your fuel system ran? Mech or electric fuel pump, regulator type, where is your fuel pressure at now after the regulator?
If its the same PSI as the kit is calling for, assuming your using the jetting in the kit, and your confident your fuel pump will keep up, do it after the regulator.
Old Jun 14, 2008 | 03:12 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
You will need 6 psi flowing. Are you fuel inj or carb?
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
