need an affordable timing retard system
Old Jul 15, 2008 | 09:19 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I need one for my 383 setup. I am spraying my car right now with a 150 shot and im high compression. What i want is something to retard my timing once spray is hit. I know some of the msd boxes can do it, however they are fairly expensive.
any other ideas?
Old Jul 15, 2008 | 11:21 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: need an affordable timing retard system
Some of the 1980's GM HEI modules (5 pin) had a timing retard mechanism built into them for the ECM to active. I forget what the retard degrees was but it might work for you. A search on google would bring up more info.
Old Jul 15, 2008 | 11:25 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
I am currently running a Mallory 685 box, works great. They run about 250 at summit. Can pull out up to 15* and has a window switch for the bottle. My last trip to the dyno, with the timing set at 34*, and then pulled 8* i only lost 10hp 5flbs.
Old Jul 15, 2008 | 11:32 AM
junkcltr's Avatar
Engine: 3xx ci tubo
http://forums.hotrod.com/70/6448119/...les/index.html
http://www.cadillacforums.com/forums...m/t-50062.html
Check out the 5 pin information. I have 5 pin module from a 1981 chevy Blazer. Search the junkyards for 1980 - 1985 chevy truck distributors. They had the cheesy computers that used the 5-pin type module. The connector has two black wires, one white wire, one green wire.
http://www.partsamerica.com/ProductD...pe=194&PTSet=A
http://www.partsamerica.com/ProductD...rtNumber=DR406
The first 305ci unit seems like a decent price.
The second one isn't that cheap.
I would check the junkyard. Maybe a complete dizzy is cheaper.
Old Jul 15, 2008 | 04:44 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
so it pulls timing once the nitrous is hit right? i just wanna make sure
Old Jul 15, 2008 | 11:14 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I ran into this problem when I started spraying. I sold my 6al box and bought a MSD Digital 6 box. Has a two step rev limiter and timing retard. I just wired the retard wire to my activation switch. So when the system is armed the timing is already pulled.
midge54
Dec 27, 2019 04:14 PM
backtothe80s
Sep 5, 2015 12:39 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
