Power valve not opening?
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Im running a mighty demon blow through carb, and at light accel ( 1/4 throttle) my afr is only around 13.5. WOT is also 13.5. Yikes. Tomorrow I'm going to bring up the secondaries 4 sizes. The primaries I brought up from 79 to 81.
Power valve is a 6.5, vacuum is 11. Runs smooth though, a little hiccup when I when rev hard in park, so I'll have to get bigger squirters I guess.
Car: 92rs
Re: Power valve not opening?
I have the same blow through Demon. Vent tube extensions and HSAB size reduction richened up mine upstairs. What carb hat are you running?
Car: 91 rs
Axle/Gears: 3.50 9"
Extreme velocity. This is my first carb with HSAB's. I think I'm a bit away from fine tuning at a 13.5 afr.
Car: 92rs
Do you have the down leg or annular boosters? I jetted up alot with no success, but the HSAB change and vent tube extensions made a big difference. The HSABs have a big effect on the fuel curve and aren't just for fine tuning.
Remember that at 1/4 throttle a fair bit of the fuel being supplied is still coming from the idle circuits (curb idle and off-idle transition ports). You may jet up and find your 1/4 throttle air fuel mix doesn't change very much.
Blow-through carbs aren't all the same. How much boost they are designed for can have a substantial effect on the A/F ratio delivered at a different boost level. One of the big changes happens to the power valve channel restriction (the amount of extra fuel metering area that comes on-line when the power valve opens). The few I've got personal experience with seem to have slightly to moderately richer jetting, a low number power valve (3.5 or so) and the PVCRs opened up anywhere from a fair bit to a ton, depending on the boost level it's calibrated for.
I offer this as being information IN ADDITION TO what was posted above, not in contradiction to it.
mdtoren
Aug 16, 2015 05:45 PM
