plug wires to use with extreme heat.
Old Nov 3, 2008 | 08:24 AM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
what plug wires if anything special are people running with turbo set ups. I looked on summit and didnt see anything that was specific for applications like turbos. the moroso race wires seemed to have the highest heat resistance and had protective sleeves to go with my guards I already have that my msd 8.5 wires melted under with out touching. thought about the accell extreme wires but they looked like a regular wire with the sleeves I already got.
Old Nov 3, 2008 | 12:59 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: plug wires to use with extreme heat.
I have used Moroso wires since the 1990s and never had a problem with them.
Old Nov 3, 2008 | 01:35 PM
lt1z350's Avatar
that is good to know since I just ordered them through summit and were 150.00 the most I have ever paid for a set of plug wires by far. I ran old moroso blue max ones 15 yrs ago and they were the worst ohm per foot out of any of them during that time but know these new race ones are way better and every single nascar team only uses them so that says something. can you check out my hot side glowing post and see what you think,junkcltr.
Old Nov 3, 2008 | 01:39 PM
jonarotz's Avatar
Car: 91 Z28
Accel has a new set with smaller porcelain boots and high temp wire. I have melted too many boots with my setup. I now run the porcelain boots on the problem wires. No more problems.
Old Nov 3, 2008 | 02:41 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I have a set of the moroso "Race" wires with protective wrap to protect from the headers, they look cool (I havent used them yet) and I have a friend who uses the same thing... He hasnt had any problems yet...
Old Nov 3, 2008 | 05:20 PM
lt1z350's Avatar
yeah sounds like the ones i just got from summit. 150 bucks and 60 for the heat sleeves that are summit brand. I know jacobs used to have a set of ceramic boots and high temp wires that were for turbo applications but coulndt find them.
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
