Turbo header question?
Old Jan 17, 2009 | 11:19 PM
1970judge's Avatar
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Why is it that Bermudez and SSautochrome only recommend small frame turbos for their headers? Is it because of the tubing OD wont support it or what? Please note, please do not respond with.."Do your research on SSAC" I don't care about that I just want to know that answer.
Thank you
Old Jan 17, 2009 | 11:47 PM
project89's Avatar
Re: Turbo header question?
its clearance issues.
but u can get upto something like a 70mm turbo on there, maybe even 76mm if they can stuff it into a t4 sized compressor housing
Old Jan 18, 2009 | 12:11 AM
1970judge's Avatar
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
So technically speaking, if i had a set of the SSAC headers that say t3/t4 flange, i could put whatever size mm turbo on there I wanted, I am not limited to small?
Old Jan 18, 2009 | 12:13 AM
project89's Avatar
yeah pretty much,the headers come with t4 flanges dont they?
so u should be able to run mid frame t4(t04 based) stuff on it
Street Lethal
Apr 30, 2019 12:14 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
PestilenceIV
Aug 20, 2015 03:32 PM
redmaroz
Aug 16, 2015 11:40 PM
