Getting ready to build a set of headers for a turbo, what do I need for material?
Old Jan 20, 2009 | 11:43 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Do headers/ manifolds for turbo's need to be of special tube or will say a set of Hedman Hustler weld up headers work as a basis? I am looking at building a set in the very near future and hope to get some help beforehand.... Any suggestions that may help me or save me a bunch of grief? Thanks guys
I should have added, it will be for a single turbo set-up..
Jason
Old Jan 22, 2009 | 09:21 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Re: Getting ready to build a set of headers for a turbo, what do I need for material?
Someone has to have a little insight... ??
Old Jan 22, 2009 | 11:28 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I think the biggest thing is that people preferably use thicker metal such as 3/8" or 1/2" thick flange and probably 14 gauge tube. Asside from that, I'm going to see how using my hedman shorty headers and some normal exhaust pipe works out.
Old Jan 23, 2009 | 07:51 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I used log style manifolds. They were compact, very thick, and easy to modify for the turbo. They are also strong enough to hold the weight of the turbo without extra bracing. The collector was 2-1/2" OD so I used the same OD tubing for the crossover.
Orr89RocZ
Apr 25, 2016 08:28 AM
evilstuie
Feb 28, 2016 03:33 PM
Golfvette
Aug 24, 2015 06:35 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
