Need advice on rear mount turbo
Old Jan 27, 2009 | 07:21 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
My friend installed a rear mount turbo t3/t4 on his 3.0L ranger and its amazing but I just was curious what size would I need for a single on a 5.7L .
I have an 87 GTA stock l98 and my goal is to reach the 350-400hp, run the car at 6 pounds boost nothing crazy and very basic.
Old Feb 10, 2009 | 07:02 AM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
Re: Need advice on rear mount turbo
youre probably better off talking to someone who has an sts kit and go by there specs but if i had to guess id say .81 a/r turbine T4 housing should do it with anything from a 60mm compressor wheel and up. i run a .96a/r on my 5.7L but i think with it being moiunted in the rear the .81 might help spool quicker, etc.
a master power MP70 (61.5mm) witha .81a/r should easily get you to your goal.
good luck
Old Feb 10, 2009 | 12:01 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
STS is great. Give them a call. They will talk to you about getting a kit perfectly made for your car. They will match a turbo to your mods done now and future mods, what do you want, quick spooling, more power, top end....they will find the right setup for you, just give them a call.
I dont want to see a response unless you called them and have feedback...
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
