87 IROC with 3 inch cross over..
Old Feb 2, 2009 | 05:06 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
so this is the plan, 355 with S475 turbo, jgs WG and BOV and CSU 750...now the problem is...
im using the ebay headers, modding the back tube so it clears the steering shaft and cutting the flanges up front and doing vbands on them...car still has ps and alt and water pump....also has a griffin rad
now i was under the hood yesterday for a few mins and noticed that there is not much room to run a 3 inch cross over pipe to the turbo that is going to be mounted on the pass side where the batt used to be...sway bar and wonder bar take up a lot of room right where the pipe would like to go....
and the sterring box is might close to the ps pump but i might be going with a small circle track ps setup which mounts on the drivers head very small...
basically i wanted to see if anyone has any pics of how they routed a crossover pipe to the turbo with the sway bar and wonder bar in the way....
any help would be appreciated so i dont start cutting up the car and makin room....thanx guys...
Old Feb 3, 2009 | 08:05 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: 87 IROC with 3 inch cross over..
I used a 2-1/2" crossover and have plenty of clearance from pulley, ps, fan, sway bar, and wonderbar. Not the best pic, but it's the only one I have at the moment:
Old Feb 3, 2009 | 07:00 PM
Charged350's Avatar
Car: 87 IROC Z28
thanx...what kinda headers you use...
Old Feb 3, 2009 | 07:26 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
I used log manifolds. I took some pics of my first TA with the turbo build if you want to check it out.
Old Feb 3, 2009 | 07:49 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by calebzman
I took some pics of my first TA....
Excellent write up....!
.... have you posted this buildup in the carb section, on the turbo forums yet?
Old Feb 4, 2009 | 07:34 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Thanks, I can't remember if I did or not since it was a few years ago. I do remember asking for carb tuning advice there b/c I could never get it to run well at part throttle.
Also, for the OP, to visually see if the crossover will fit, get a short peice of 3" tubing and move it along the front of the engine to make sure it clears everthing. All the accesories looked really close when I was building mine, but after I did that little test, it was easy to see that I had enough room.
Old Feb 4, 2009 | 09:35 AM
Thanks, I can't remember if I did or not since it was a few years ago....
Had to do it, Click Here....
Old Feb 11, 2009 | 07:22 PM
daverr's Avatar
heres my 3" crossover on my remote front mount .almost done.
Attached Thumbnails 87 IROC with 3 inch cross over..-dsc00027.jpg   87 IROC with 3 inch cross over..-dsc00029.jpg
Old Feb 11, 2009 | 07:51 PM
Charged350's Avatar
Car: 87 IROC Z28
daverr that is sweet, pretty much the same thing im doing, i got the turbo in the mail, and its huge, i have to mount it in the front of the motor like you did, how do you plan to support the turbo there....if you have any more pics that be great....abd what kinda headers are those they look nice
Old Feb 11, 2009 | 10:52 PM
daverr's Avatar
most likely the turbo is going to be mounted to the front plate.The headers are custom 304 stainless steel.here are more pics.
Attached Thumbnails 87 IROC with 3 inch cross over..-david-001.jpg   87 IROC with 3 inch cross over..-david-003.jpg   87 IROC with 3 inch cross over..-dsc00011.jpg
Old Feb 11, 2009 | 11:03 PM
daverr's Avatar
more pics
Attached Thumbnails 87 IROC with 3 inch cross over..-dsc00025.jpg   87 IROC with 3 inch cross over..-dsc00030.jpg
Old Feb 12, 2009 | 05:47 PM
Charged350's Avatar
Car: 87 IROC Z28
nice man....thats a big turbo...im diggin into my car in the next couple weeks and im gonna try to put it infront of the water pump where the rad used to be jus gotta figure a mount to build.....
Old Feb 12, 2009 | 11:48 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i think your missing valves......
Old Feb 16, 2009 | 07:06 PM
Charged350's Avatar
Car: 87 IROC Z28
yeah looks that way
Street Lethal
Apr 30, 2019 12:14 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
