Where to find adj. mass air sensor or larger?
Old Feb 17, 2009 | 03:49 PM
customirocz's Avatar
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
I was wondering if anyone can help, Do they make a larger or adjustable mass air? Also will it help add more fuel in top end?
Old Feb 17, 2009 | 06:47 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Where to find adj. mass air sensor or larger?
Put your mass airflow sensor in a 4" tube and re-calibrate the ECM. If it is too lean, then adding fuel will help.
Old Feb 17, 2009 | 06:50 PM
tequilaboy's Avatar
Yes. PM sent.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 23, 2015 12:52 PM
92purpz28
Aug 11, 2015 02:30 PM
