NOS 15982 Window switch, erratic rpm
Old Mar 4, 2009 | 04:32 PM
widarsson's Avatar
Car: 1988 Camaro 11.08s / 130.5mph
Engine: 383 HSR
Transmission: 700 R4
Axle/Gears: 9-bolt 3.27
Hi
I tried my new NOS 15982 window switch and the rpm readings seem wrong, or at least fluctuating in a very bad way.
At idle the rpm is the same as on the Autometer gauge but with increasing rpm the window switch reads about double the value of the Autometer. Now and then it falls down to correct rpm but seconds after it doubles again.
Everything connected as outlined in the manual and the other functions are working ok. I suspect a bad/distorted/wrong tach signal, but it is connected to the same wire as the Autometer gauge.
I have the tach wire connected to the white wire going to the coil.
There is a white wire going between the coil and distributor also. Is this a better place to tap into?
Or are there any places where I can get a better signal for the window switch? At the ECU?
The car is a 1988 Camaro 350 TPI/HSR, stock ignition.
BR
Jan
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
