-10 an fuel line routing?
Old Mar 11, 2009 | 06:15 PM
86trbota's Avatar
Car: 86 trans am
Engine: 383 dart 215 billet 84mm s400
Transmission: th400
Axle/Gears: 3.08
just wonderin if someone one here has ran -10 an feed and return lines on a third gen and how they routed them. kind of leary puttin them in the stock location runnin down the drivers side of the tunnel next to the torque arm. how did you get them to the eng compartment, up and over the tranny like factory did? thier is room but if ya brake a trans mount they could be smashed.
thanks Alex
Old Mar 11, 2009 | 06:32 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: -10 an fuel line routing?
I have a -10 aluminum line, the tank has a sump and feeds to a bg400 pump and has a ss flex line that goes over the axle on the passenger side, then goes toward the tunnel and then as soon as clearence is avaliable it diagonals over to the passenger fender and up the wheel well entering the engine compartment near the hood hinge.
Old Mar 11, 2009 | 07:39 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i run #8 both ways on the drivers side with no problems i just tucked them really close to the brake lines and wire tied them every couple inches and use some DEI heat sleeve near the drivers side header where it comes out of the tunnel under the brake booster
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
