Has anyone used MSD Adjustible Timing Control Part#8682
Old Apr 15, 2009 | 09:30 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
Transmission: WC T-5 (untill it breaks)
Axle/Gears: 3.73 Posi
Has any body used the msd adjustible timing control to retard there timing for the use of nitrous, seems like it would be a good deal because you couls put it back to your performance setting after you were done spraying, and could just turn the dial back down when you were getting ready to hit the"Go Button", and not have to mess with turning the distributor by hand. Any help would be great!
thanks
Old Apr 15, 2009 | 10:31 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Re: Has anyone used MSD Adjustible Timing Control Part#8682
I run one with my setup and it works flawlessly. Only problem I have found with people is that sometimes they tend to forget to retard it before the hit. One time of that and bubye!
Old Apr 15, 2009 | 10:38 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
is it pretty easy to get dialed in?
Old Apr 15, 2009 | 10:02 PM
izcain's Avatar
Engine: 584
Takes a bit to get it. In order to get it set to have both advance and retard I just set it in the middle then set the timing where I wanted it, then adjust it from there. Just remember to retard the timing before hitting it.
I found that since I pull about 8 degrees out I end up setting the timing with the dial about 3/4's of the way up so I have alot more room for retard but not so much for advance.
Old Apr 16, 2009 | 06:01 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
Sounds very good, But sorry for so many questions but looking at the directions on line there not to detailed, but how exactly did you set it in the middle. In the directions it says something about putting the dial at 15deg i think and setting the distributor or something like that. Thanks for the help its really appreciated.
steve
Old Apr 16, 2009 | 06:14 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
I am guessing this is how you did it, Tell me if Im on track or not.
1.install timing retard with the dial on like the 13deg setting
2.start engine and adjust timing with light to the catory setting
3.adjust dial from there
if my thinking is right that would give you about 2deg of advance and about 12 deg of retard.
what do you think?
Old Apr 16, 2009 | 10:13 AM
izcain's Avatar
Engine: 584
Yep thats how to do it if you want to be able to retard more!
Pretty simple setup really but it works well!
Old Apr 16, 2009 | 10:43 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
O ok thanks, sorry for the onslaught of questions, but i have trouble with reading directions that are not to detailed, and figureing out what they mean, much easier to find somone who has did it before, I think im going to get me one tomarrow and see how it works.
thanks again!
Old Apr 20, 2009 | 12:53 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
i'm using one of those timing boxes too but i turn the **** on it all the way to the 15* mark, set the timing and then retard from there....that way even with the **** turned all the way, your timing will not advance past what you originally set it at.
Old Sep 19, 2009 | 07:57 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates?
Old Sep 1, 2014 | 09:52 PM
westonedelbrock's Avatar
this is an old thread but can you en buy these any more? I'm thinking of building a 377 with a 150 shot and I'm very new to the spray. I'm open for options. I'd prefer something that when I arm the system and am at WOT it retards itself but I could make due with something like this, until that time I forget to retard the timing
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
