SC Boost Gauge/FMU/Ignition- Boost Controller Vacuum Source?
Old Apr 26, 2009 | 11:36 PM
90 L98 TransAm's Avatar
Car: 90 L98 TA, 03 WRX
Engine: Vortech Supercharged 5.7 L
Is the cruise control vacuum line an acceptable vacuum source for a supercharger boost gauge/FMU/and Ignition Boost Controller or do I need to tee in to the vacuum line right at the intake manifold?
Old Apr 27, 2009 | 09:53 AM
Damon's Avatar
Re: SC Boost Gauge/FMU/Ignition- Boost Controller Vacuum Source?
I wouldn't use it for a couple of reasons, the primary one being the check valve that doesn't allow vacuum to drop off when you open the throttle. GM puts a check valve in that line (along with a vacuum reservoir) so that your curise control and HVAC controls still have vacuum to operate them briefly if you happen to smack the throttle open to pass somebody, climb a steep hill, etc.
I'd do a fresh line straight off the intake for a vacuum connection that important.
Old Apr 27, 2009 | 10:04 AM
Thanks Damon.
I was concerned about that fat little valve and possible affects of the cruise control servo operation on the SC equipement that requires a vacuum source but tried it since that hose goes right by the FMU, boost gauge MAP sensor and MSD box.
I'll go straight to the intake manifold upstream from the check valve.
Old Apr 27, 2009 | 10:41 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Just tee into the fuel pressure regulator port on the back of the plenum....
Hotrodboba400
Dec 10, 2019 07:07 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
