where to find 3.75 inch air inlet tube
Old May 5, 2009 | 12:57 PM
sailbrd's Avatar
The air inlet diameter on a D-1 is 3.75 inches. Does anyone make Aluminium tube in that diameter? Other ideas for making air inlet tubes?
Old May 5, 2009 | 03:34 PM
gunner53227's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 10 bolt/3.73
Re: where to find 3.75 inch air inlet tube
I can't find 3.75 inch tubing, but there are alot of parts for intakes on this website that you might be able find something that will work. I have never ordered from them, but check it out.
http://www.intakehoses.com/Merchant2/merchant.mvc?
Old May 5, 2009 | 03:55 PM
Ronny's Avatar
spectre products has a good selection of alum tube. i think both jegs and summit will show the sizes online. I assume D-1 is Procharger. I would check their site as well.
Old May 5, 2009 | 08:13 PM
sailbrd's Avatar
Gunner,
I found 3.75 silicone tubing, that helps. No Aluminum tubing.
Ronny,
Checked Spectre no go there. Procharger site sucks. May have to call them and see what they have.
Maybe a 3.75 silicone hose would allow me to adapt a 4 inch hose.
Old May 6, 2009 | 08:34 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Why not just use 4" tubing and step it down 1/4" at the inlet to the D1? That way you can use whatever material you wanted. I used 4" ID pvc tubing for my turbo inlet which was about 1/2" larger on the OD, so I added a rubber reducer with clamps and it works great.
Old May 6, 2009 | 02:23 PM
Ronny's Avatar
Procharger catalog lists universal tube kit at 3.00 and 3.50 inch.
D-1 unit inlet hose dia at 3.75 no inlet ID shown. outlet at 3.00 outlet ID 2.62
Intercooler is 3.00 inlet and 3.50 inlet
Bonnet inlet 3.00 or 3.50.
I would email them on what adapter may be needed.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Street Lethal
Aug 12, 2015 11:33 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
