Getting Rid of Current Compression Options??
Old Jun 19, 2009 | 08:42 PM
Drone358's Avatar
Hey guys gotta 355 carb motor and have 10:6:1 Compression and wantin to install D-1 Procharger
Now my question is they gotta make a lil spacer or shim that sits on the deck of the block under the head right? Its gotta be the simplest way to go jus get longer bolts if needed. Jus wantin ur opinion and advice!
Thanks!
Old Jun 19, 2009 | 08:44 PM
Drone358's Avatar
Re: Getting Rid of Current Compression Options??
And i know they make thicker Headgaskets too but wasn't sure how much a difference it would be
Old Jun 19, 2009 | 08:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
The last thing you want to do is get a thicker head gasket or spacer. That will destroy your quench and increase detonation.
Best bet is to swap pistons or get a head with a much larger CC chamber. Going from a 64cc or so up to a 75-76 cc will bring you down in the mid 9's to 1 which is better with a blower motor. Just make sure your ring gaps arent too tight like a n/a motor usually is and it should be ok. Make sure the tune is dead nuts and you will be much better off as well
Old Jun 19, 2009 | 09:00 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
I am pretty sure they do not make a spacer like that, but you would be suprised how much difference a thick head gasket makes. I have even seen an article where they stacked head gaskets!
One of the many problems you will have with getting rid of compression this way is your intake seal, raising the heads will alter the angles and could pose problems.
Also the wedge type combustion chamber that is used on sbc is designed to use the tight distance between the piston and the closed side of the head to get complete combustion. Whenever you increase this clearance you are actually making the engine more prone to detonation, even with less compression.
Long story short, buy new pistons or larger chamber heads. Any other way that you go about reducing compression will be half***, and probably not even get you close to the 9 to 1 or less you should be shooting for.
Old Jun 30, 2009 | 04:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Better question - what parts do you have now?
Pistons (part number, size, etc)
heads (chamber size, port size)
deck height
camshaft (part number. not "race cam" or some stupid BS like that)
Old Jul 11, 2009 | 01:06 AM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Just to try and help you out,
Right now i run 10 lbs on my 383 with 10.7-1 CR
ported vortec heads
292 Comp cams "NX express" 274/292, Lift .487/.501 on a 113 LSA
850 Demon blowthrough with alot mods
RPM airgap intake
Summit BTM digital ign.
MSD Probillet Dis.
Baster 2
ect ect just to give you the basics
I run water-meth and pull a lot of timing under boost. I know i am leaving alot on the table but i dont have the cash to pull it back down for new pistons. IT CAN BE DONE! But like stated you have to be spot on with the tune. A wideband is a MUST! watch your AFR really close. at WOT i dont like to see my AFR over 11.5-1. read plugs and make sure you have a good fuel system. everyone told me that it could not be done, and so far its worked great. its all in fuel and timing. i am really conservitive on timing, ran about 34* and pulled between 2-4* for every pound of boost. Just make sure your on top of it and you will be fine.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
