450rwhp
Old Oct 31, 2009 | 12:06 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
450rwhp
Well, my current setup is a zz 383 crate motor 425hp with 460ftlbs flywheel with a superram intake,bbk 52mm throttle body, and a d1sc procharger. I was thinking of removing the d1sc procharger completely and trying to just go all motor. Is my motor capable of making 450rwhp without the blower. would a bigger cam be able to do this power increase. here is the break down on my motor:
- 4340 forged crank
- forged rods
- hypercautic pistons 9.5 to 1
- 222/230@50 509/528 with 112
- dougs long tubes
- Fast burn heads with gm 1.5 roller rockers
- stage II stewart water pump
- accel superram unported
- bbk 52 mm throttlebody
- 42lb svo injectors
currently making 400rwhp with blower but the procharger is just giving me a headache i am thinking all motor might be a little bit more streetable. any ideas?
Old Oct 31, 2009 | 04:06 PM
daverr's Avatar
Re: 450rwhp
- 4340 forged crank
- forged rods
- dougs long tubes
for all motor u will need better cylinderheads,solid roller cam and more compression.
Old Oct 31, 2009 | 04:24 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: 450rwhp
Nope, not too likely!!!!
Old Nov 1, 2009 | 10:16 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Re: 450rwhp
well maybe i will stay with it, just found out my headache it was a seized smog pump. ripped both belts the supercharger belt and the serpintine belt.
Old Nov 1, 2009 | 11:03 AM
AC's Avatar
AC
Car: Used to drive a camaro
Re: 450rwhp
Is it just me or does 400 RWHP on a D1 procharged setup seem low??? My friends 305 (YES 305) with a D1SC is putting down 381rwhp. I've seen his dyno sheet, seen the video and know his setup. Stock bottom end, just world products heads and headers. Stock TPI intake.
Old Nov 1, 2009 | 01:39 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: 450rwhp
Old Nov 2, 2009 | 10:18 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Re: 450rwhp
well my car really needs a way better tune. i am trying to get one of those fast xfi systems so i can really get it going.
Old Nov 2, 2009 | 02:21 PM
AC's Avatar
AC
Re: 450rwhp
How much boost was the car puttin out at peak? What was the AFR? I'm taking a guess in thinking you might have been running lean with those injectors possibly. Did you just put a "chip" in, have someone else tune or did you DIY tune ?
Old Nov 2, 2009 | 11:40 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Re: 450rwhp
well i was getting like 50 to 60 psi max and then it was running out of fuel, u think that the svo 42's might be to small.
Old Nov 3, 2009 | 02:20 PM
AC's Avatar
AC
Re: 450rwhp
You mean 5 to 6 PSI right? The 42's could be a bit small. There's tons of calculators around to determine that. I run 60#'s and know I won't run out of fuel.
rwerk91
Jul 25, 2013 09:02 AM
onebad85z28
Apr 8, 2012 08:29 PM
91camarosRS
May 7, 2010 03:31 PM
super_kev
Nov 28, 2004 09:25 PM
t-top89
Oct 13, 2004 10:36 PM
