twin turbo 383
Car: 86 Iroc-z, 92 camaro
Engine: Ls1, 3.1 v6
twin turbo 383
ok i want to build a twin turbo 383 camaro i have a 92 camaro i want to put it in. i am kind of new to this turbo stuff need some help on this project
Car: Used to drive a camaro
Re: twin turbo 383
search search search. Alot of people have chimed in over the years about turbosf. Orr89RocZ just finished his 401 twin turbo and it is SIIIIICK! BBS is still offering turbo headers I believe but their 1 off's now I guess.
Car: 92 Z28
Engine: Boosted LSX
Re: twin turbo 383
deff. start reading this site. along with http://www.theturboforums.com/smf/index.php
Your leaving way to much missing info.
Your budget $$
Your HP / ET goals.
Your fab / welding skills.
Your budget $$
Your HP / ET goals.
Car: 77 and 79 Vette 85 Jag 93 Chevy p/u
Engine: 350 all tpi in vettes and jag tbi i
Transmission: 700r4 all but pu is 4l60e
Re: twin turbo 383
79 corvette currently 350 cubes lt-1 crank and rods forged flats brodix heads lt-4 hot cam msd 6al btm ignition 750 demon carb 144 wiend blower sanderson headers flowmaster 2.5" mufflers 700rn 5 gear planetaries 9 disk 3-4 pack billit survos wide band full manual valve body 2500 stall much shiny stuff contemplating swap to tpi with turbo have tpi manifolds portenplenum did some work on runners and opened up base built a harness to run 7727 ecm pondering if to use code $59 or some other software with system
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: twin turbo 383
730 ecm and code $59 is working well for me so far, cant complain. Its priced right too. basically free download and 40 bucks for ecm. Just add the map sensor and wiring to make it all work.
twin turbo builds can get pricey but depends on how you do it and how good your fab skills are
To get an idea what its going to take, need to know your goals for the car and what parts you have now and/or plan on using for the build. That will help determine your budget.
LT1Formula
Oct 8, 2015 08:34 PM
