times with nitrous
Old Jun 3, 2007 | 12:47 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
times with nitrous
Just wanted to say you really don't have to spend an arm and a leg to post some decent times. 1992 Formula 350 with 114,000 miles. Only mods are a SLP Cold Air Kit, NOS kit #5151, and a set of M/T ET Streets. At Richmond Dragway and in 95 degree heat with ridiculous humidity the car went 12.8518 @ 106.79 MPH.
Old Jun 3, 2007 | 12:50 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: times with nitrous
What was your 60ft times?
Do you have 1/8th mile times?
Is that a dry or wet kit?
Old Jun 4, 2007 | 10:20 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
What shot are you running? I am spraying a 75 and I was wondering what times i could get with that.
Old Jun 4, 2007 | 10:22 PM
firstfirebird's Avatar
Take it to Moroso
Old Jun 4, 2007 | 10:39 PM
I know, but I got the old lady bit**n about money so she is cuttin me off for a few months.... how you been john?
Old Jun 5, 2007 | 08:45 PM
PAFORM350's Avatar
Engine: 5.7 L98
I bought this kit from Scoggin Dickey on clearance for 360.00. It's the wet kit. I am using the 150 hp jets. My 60ft time was 1.91. 1/8 mile 8.24. I am sure I can go faster than this. I will post more times as they come.
Old Jun 5, 2007 | 10:53 PM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
My 92 Formula went 12.34 @109 with that same kit but my car has headers a mac catback and a 2800 stall. Stock longblock with 82k on it. Oh btw that kit is run very very fat lean it out a little bit and it WILL pick up a bunch. My car on the 150 shot put down 355/463 on a 9.9 afr
Old Jun 5, 2007 | 11:43 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What is the part #? I wouldn't mind getting some nitrous on top of all my mods and seeing what I could run.
Old Jun 6, 2007 | 10:04 PM
Sprayed92's Avatar
Car: 92 Formula
NOS #5151
Old Jun 6, 2007 | 10:27 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
NOS kit, 150 shot, 355 went 12.62/111.862 mph.
Auggie
Old Jun 6, 2007 | 10:38 PM
Auggie's Avatar
Pic of plate mounted system.
Auggie
Old Jun 7, 2007 | 02:13 AM
F-Body Demon's Avatar
anyone else got times for L98s or LG4s?
Old Jun 25, 2007 | 06:00 PM
The Man's Avatar
92 camaro 5.7 LT4 hotcam,Hooker LT, True Duals 3" with X-pipe, Art carr 9.5" 3400stall,SLP runners with ported intake. 9" with 3.89 gears, 28" ET Drags.
Custom kit, With N2O Big Shot set up-6AN with a Nitrous Express Shark Nozzle and jet pack. I use 2 steps colder Ac plugs, gap them .020, Walbro 255, stock timing 6* on pump gas(93).Ran it like this for 2 years.
On motor 8.20-8.30s 82-83mph 1.65-1.68 60ft
On 175jets(it made 195HP to the wheels) 7.13@96mph 1.50 60ft
Old Jun 26, 2007 | 09:24 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Nice Formula you got there man. Very clean. Runs real good too! Ive seen ya out there quite a bit the last few weeks. Ive been running my wifes dark blue SS alot lately,getting used to some new parts on it. Look me up sometime when your out there..
Old Jun 29, 2007 | 06:46 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Not bad, I did about the same lil better with a 2400 stall (s10), with pretty much the same on my Formula.
Old Jul 3, 2007 | 12:23 PM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
Nice times guys I pulled a 13.02@104 w/ a 100 shot dual nozzle setup similar to the old 5151 kit. mods included as&m runners accel base, 1.6 rr's, 2800 stall et street radials, slp headers and mufflex catback. You must also take into account that this time was with a density altitude above 6000' so you can do the math. I have yet to hook the nitrous back up with the new stroker stealthram cc306 combo.
Old Jul 12, 2007 | 09:38 PM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
nos 5151 100 shot on a 355 tpi 5 speed car 3610lbs race weight - 11.87@115
Old Nov 8, 2009 | 04:17 PM
PAFORM350's Avatar
Engine: 5.7 L98
new best time 12.41@109 with only 900 lbs pressure
video of it.
http://www.youtube.com/watch?v=Xm8lWoRxJ98
Old Nov 28, 2009 | 02:28 AM
patricksmithahh's Avatar
Car: 90 corvette
Engine: l98
Transmission: built 700
Axle/Gears: stock
bone stock l98 in my corvette a hundred shot and drs went 11.55 @ 118
Old Nov 28, 2009 | 03:59 AM
Kyle86's Avatar
Car: 86 Camaro IROC-Z28
Engine: 4.8 LS 68mm turbo
Transmission: Turbo 350
Axle/Gears: 3.08 10 bolt
Dang that's pretty good!
Old Nov 28, 2009 | 01:50 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
thanksss
i cant wait to get it back to the track now it has heads cam lt headers exhaust msd ignition drag radials and a tune....just gotta get a new fuel solenoid cause mine broke
oh and that time was in vegas heat with the cheapes nos sniper kit money can buy
Old Nov 28, 2009 | 02:08 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
wow i only got 14.2 in my 3.1 with a 125 shot that baby took it like a champ.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
