effective compression ratio calculator site...
Old Dec 8, 2009 | 05:36 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I was trying to find max CR I can run with my setup and found this website and it gave me the effective compression ratio. Powerdyne says 12.5-13.10 is good for a centrifugal supercharger. Hope this site helps someone
http://www.rbracing-rsr.com/compression.htm
Old Dec 8, 2009 | 11:08 PM
daverr's Avatar
Re: effective compression ratio calculator site...
it is a bit misleading.... My car i could run 16 psi of boost on pump gas. According to the calculator my effective compression is north of 16:1 compression. If it was really 16:1 compression there is no way i could run pump gas.those effective calculations are worthless imo.
Old Dec 9, 2009 | 12:31 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I agree that it is misleading. Mine comes in at 15.4:1 with the calculator. I run 87 octane sometimes with water/alky spray during boost.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
