What Rods??? What comp. will this yield????
Old Jan 9, 2010 | 06:53 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
A little help here
this pistons I am running. I got them from a friend for free brand new cause he went another direction.
http://www.summitracing.com/parts/TR...F&autoview=sku
what rods should I use? the setup will be those pistons, vortec heads, Ported runners and plenum, etc.
I want to know what the comp. Ratio would be and what rods would hold up the best for what I am doing. It is going to be a procharger setup. Running 10-12 Pounds of boost.
Also I will be converting the Computer to EFI Connection Product's and it will run a LS1 computer and be easy to tune.
Also what would be a good cam to run with this setup?
forgot to add it will also be intercooled.
Old Jan 9, 2010 | 08:49 PM
Damon's Avatar
Re: What Rods??? What comp. will this yield????
It doesn't say what the dish volume is in the description, but I'd estimate it about -12cc dish. They're designed to be used in a standard bore 350 block (no overbore) with standard stroke 350 crank and 5.7" rods. Compression ratio will depend on the heads. With big 76cc chambers you'll be roughly in the low 8s. With 64cc chambers you'll roughly in the low 9s.
Too many variables to say any better than that without more info.
Old Jan 9, 2010 | 08:58 PM
Axle/Gears: G92
the heads are just stock 96 vortec heads.
thanks for the info
Old Jan 10, 2010 | 10:07 AM
AC's Avatar
AC
Car: Used to drive a camaro
96 stock Vortec CC is 64cc. You need to get the volume of that piston, consider the head gasket thickness when thinking about CR. You could stick with stock length rods. If your pushing 10-12 lbs just make sure you're using an intercooler and 93+ octane. 91 will be fine but if you have 93 available just use it. I'm not able to find anything on volume for those pistons but from what I can find I'm guessing you be around a 9.8:1 CR which is still safe.
Old Jan 10, 2010 | 11:24 AM
Axle/Gears: G92
thanks, I have never messed with a power adder car so I have no cool what I should do for the headgaskets as for size and such so suggestions are helpful..
Old Jan 10, 2010 | 02:43 PM
AC's Avatar
AC
Head gaskets? Use a MLS (multi-layered steel). I have a 4.030 bore block and use a 4.060 bore gasket. .041 compressed thickness.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
