racing chip?
Old Jan 7, 2010 | 05:19 PM
101btp's Avatar
Car: 86 Trans am
Engine: workin on a 383 for it!
racing chip?
I have a semi stock 86 unibody trans am, the computer is stock but has any one added racing chips before? I was looking on autozone's website and came across some chips under performance about 120.00-160.00 would it be worth it or is their a lot of tuning to go with?
Old Jan 10, 2010 | 08:02 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
Re: racing chip?
For FBody's They are mostly a gimmick, much like the electric superchargers on ebay. You can expect to see a HP increase of maybe 5, not worth the money and they will be useless if you do any other major performance upgrade since they are designed for stock engines.
Sometimes on other engines they raise the rev limiter, which can make a dramatic affect on performance, but since our engines are not RPM limited (in the sense that the rev limiter is affecting the powerband) there is no improvement to be had.
Old Jan 10, 2010 | 12:52 PM
101btp's Avatar
Car: 86 Trans am
Re: racing chip?
o ok thanks I had been woundering about that
Old Jan 11, 2010 | 04:13 PM
Ronny's Avatar
Re: racing chip?
you might want to consider increasing the timing a tad. See how that works.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
meeklay812
Oct 1, 2015 03:46 PM
