Blower Questions
Old Jan 28, 2010 | 12:23 AM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Blower Questions
I was thinking about superchargers and how they "take power to make power" and I want to start hacking apart a blower and trying to build something, I won't mention what I am attempting to do but if it works I'll let you all know.
I have a few concerns though:
- As the motor revs higher, the crank is spinning faster but is a supercharger building more boost at those higher RPMs or is it forcing a constant amount of air after a certain RPM?
- If so, around what is the specified RPM that it is forcing maximum air in at?
I'll be building a blown motor on a test stand, it's a real hack and slash job and you'd all think I was crazy for even thinking about it if I told you my goal; no idea if it will work even but I am trying it anyway.
Old Jan 28, 2010 | 09:36 AM
KS91Z28's Avatar
Re: Blower Questions
That depends on what kind of blower you're talking about. Centrifugal superchargers build more boost the higher the RPMs.
Old Jan 28, 2010 | 02:04 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Is their a problem with boosting fully at idle? I'm trying to figure out exactly what I need to do to make this idea work.
Old Jan 28, 2010 | 05:47 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
boosting at idle will create too much air with not enough fuel, you would need to provide fuel which will in turn raise the rpm
Old Jan 28, 2010 | 06:04 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I'm trying to figure out exactly what I need to do to make this idea work....
I have no idea why you would want full boost at idle, unless you mean off idle, or part throttle, not to mention what you consider full boost (30-psi?), and if this is the case, most guys will hit it with a shot of nitrous when they launch in conjunction with the blower for similar effect. Your tune better be spot on though....
Old Jan 28, 2010 | 06:11 PM
Here is (just about) full boost off idle, supercharger w/nitrous....
http://videos.streetfire.net/video/F...III_687144.htm
The only other way is with a transbrake, but that wouldn't be considered @ idle then....
Old Jan 29, 2010 | 05:41 PM
danandamy's Avatar
Car: 86 Camaro
There was a good article in Car Craft a few months back breaking down the difference in the different styles of blowers. In a roots type blower for instance, they are designed more to move a volume of air than to actually build pressure. A centrifugal blower on the other hand, is designed to do the opposite. You might check their web site and see if you can find it.
Dan
Old Feb 10, 2010 | 10:09 AM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
that vid was awesome! that has to be hell on a car though, i cant see that thing holding together with that kind of abuse
Old Feb 10, 2010 | 10:55 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Sounds to me like you're trying to have the blower spin max rpms almost all the time. That sounds cool and all, but would require a MASSIVE BOV unless you also have it spin much less rpm when not under a load. Actually if you were to adapt a belt/pulley system from a snowmobile, this could be very plausible.
Old Feb 10, 2010 | 01:05 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Fast82Z,
Are you meaning like a reverse centrifugal clutch. So it has a smaller pulley diameter that would get larger as the RPMS rise to "slow" the blower as the engine RPM's rise. That would work great and be awesome for mid range power.
OP,
I know the twin screw type blower on the trailblazer SS makes boost pretty early in the rpm range and there is a relief valve on the blower that opens progressively to maintain at the maximum boost as the engine spins up. I am not sure of the exactly pressure levels though. This seems like what you are trying to accomplish with a centrifugal blower, if I am understanding correctly.
Old Feb 18, 2010 | 07:55 AM
Pocket's Avatar
Car: 91 Trans Am
Ignoring the CV setup weighs around 55lbs, what benefit would he have from spinning the blower up where conventional methods dont. The engine would still be at idle and the blower at whatever RPM the CV spring was set for
Frozer!!!
Jan 19, 2024 04:55 PM
soarestransam
Sep 1, 2015 04:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
