Need a 12V source to power N2O ....
Old Mar 1, 2010 | 04:37 PM
Ronny's Avatar
I am anticipating adding NOS universal EFI kit this spring.
I need to locate above.
I was thinking of using a feed off of at rear my fuse box. I did that once with adding an accessory for my boat.
I believe there are may be one open unused fuse per service manual(car in barn till 4.1)?
If not, how about using Circuit 15 at fuse box which is turn signals-fog lamp-back up light as those will be seldom used when N20 come on? 15 AMP fuse there.
1984 Vette.
Old Mar 1, 2010 | 11:09 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Need a 12V source to power N2O ....
The solenoids need to be wired (through a relay, of course) directly. Trying to draw power for them from the factory harness is a very bad idea. Wire them to back post on the alternator or to the positive battery terminal.
Old Mar 3, 2010 | 09:33 AM
Ronny's Avatar
Why would a 12V unused fuse on fuseblock be a bad idea? Are you suggesting voltage would be intermittant?
Old Mar 10, 2010 | 11:49 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
There is at least one open constant 12v port open at the fuse box under the dash and I think 2 switched 12v ports. I use the switched 12v port for my nitrous arming switch and never had a problem.
Old Mar 10, 2010 | 01:34 PM
Ronny's Avatar
Thank you. That is what I wanted to hear. Would not the feed wire to that fuse box be beefy enough? Mfg NOS suggests feed line to solenoids to 14 GA wire. I presume I need to use a 20 A fuse.
Old Mar 12, 2010 | 02:44 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Are you talking about the nitrous arm switch or the power to the 'noids? Always use a relay when powering the 'noids.
You can find any basic nitrous wiring diagram that will tell you how to wire the relay on the 'net.
Old Mar 12, 2010 | 03:15 PM
Ronny's Avatar
I have the mfg NOS wiring diagram and the EBL-ECU diagram as well.
I am refering to the lead to 'noids. That needs a 12V source. The lead to arming switch gets a 12V switched which I have already at manifold which was for the prior EGR. My fuse panel has two unused circuits. My question is the wire from battery that serves those unused circuits are they beefy enough to handle the current to the solenoids. NOS recommends min 14 ga wire to solenoids to relay to ground. ECU to relay to arm switch to ground need not be as large for gauge. Thanks.
I just looked at SM and it looks like the FB has power to it fed by 10 and 12 ga.
Old Mar 12, 2010 | 05:11 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I used the cigarette lighter wiring to power my nitrous kit on both my 84 Z and my 2000 T/A.
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
apie2546
Aug 8, 2015 07:12 AM
