nitrous hook up
Old Mar 26, 2010 | 08:49 AM
jcrouse90's Avatar
nitrous hook up
ok so i know this might sound dumb to some people.. but on my cheater kit i have the micro switch and i dont want to use it..i just want to bypass it and use a plain old button.. is it possible?? and how easy is it to do that
Old Mar 26, 2010 | 01:38 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: nitrous hook up
You mean a button you can push by hand? I don't recommend it, you only want to be on the bottle at WOT, running the micro switch is a good way guarantee that is the only time you are spraying.
Old Mar 26, 2010 | 02:42 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: nitrous hook up
I agree. Having it on a button can get you into trouble. If you hit the button under 3000 rpms it will catch fire under the intake and potentially explode. I have whitnessed this twice from guys running buttons.
Old Mar 26, 2010 | 02:52 PM
Re: nitrous hook up
I don't know about it catching fire, I have my window switch set at 2500 and haven't had that problem. I just know that bad things like detonation can occur engaging it before WOT.
Old Mar 26, 2010 | 02:56 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: nitrous hook up
Run Both, the Micro switch will Let it only work at WOT.
THINK OF IT HAS A SAFTY SWITCH.
this is the way NOS wanted it to work with the shifter button.
also install the Gas pres sending unit switch, this to, is a safty switch.
making sure, if your fule presr falls off, it shuts the NOS off.
i have been running NOS from back in the 80s. and with all the right saftys in place, you will never have anything go wrong, Ever.
Piece of mined.
Old Mar 27, 2010 | 07:14 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Re: nitrous hook up
I have watched two different cars blow the intakes apart from fuel puddleing in the intake.
Old Mar 27, 2010 | 09:38 AM
Re: nitrous hook up
they need to brush up on how to set up, and use there NOS.
you can use a Button, I do, have for 25 + years.
it's set up to work only at WOT
and Fuel over 7psi (will not work at anything under 6psi)
about half of the KaBooms, are at the start up.
Old Mar 27, 2010 | 12:51 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: nitrous hook up
window switch period....why take an unecessary risk?
Old Mar 27, 2010 | 03:26 PM
Re: nitrous hook up
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
