Nitrous Purge Line
Old Apr 27, 2010 | 11:16 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Nitrous Purge Line
I am installing a lighted purge kit. The kit contains (2) small sections of metal line which are way too short. Is there a flexible line that I can use to go from the solenoid to exit the car? If so, can you provide a part number?
I did not think rubber or PVC line will hold up.
Thanks for the help!
Josh
Old Apr 27, 2010 | 11:20 AM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
Re: Nitrous Purge Line
just go to a parts store and get the copper line used for running a mechanical oil pressure gauge. its flexible and the same size. plus the give you like 5ft to work with and its around 10 bucks
Old May 13, 2010 | 11:36 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You can also use -3 nitrous line, they sell it in 3ft, 6ft, 9ft, etc. That is what I am using.
Attached is a pick of what it looks like purging.
Old May 13, 2010 | 12:15 PM
bcl3rdgen's Avatar
Engine: LT1 Hotcam only
Axle/Gears: 9" 4.30 gears and a Locker
Call Nitrous Outlet and they will fix you up. Here is a link to the dual line kit I am running, purging pic can be seen to your left (avatar). http://www.nitrousoutlet.com/catalog...4&product=2757
83 Crossfire TA
Jan 3, 2016 01:26 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
